Parcel fabric. Topology woes.
1021
07-27-2019 06:36 PM
JeffHyder
I am trying to load a topolgy to a parcel fabric. I have fixed the 6000 errors and have validated= no errors, I have also generated a summary and it now shows zero errors and zero exceptions. When I try to run the tool  I get this error "The spatial resolution of the input feature class must be high resolution"
Importing topology.
Failed to execute
I am using a parcel fabric I created name NewlFabric.
My input (topology) feature class is my... Parcel Lines
both in the same geodatabase
Help ??? .........................Please and thank you!
JeffHyder
Do I ask stupid questiopns? No one ever replies to my posts.
TimHodson
Hello Jeff, sorry for the delay. A good place to get answers to parcel fabric questions is on the Land Records group: Land Records
For your question:
1. you could start by looking at the properties of your geodatabase, and look at the Upgrade Status. If it can be upgraded you will see the Upgrade Geodatabase button on the properties page:
2.a) Next open the feature dataset's properties:
...and
b) check to see if the Geometry properties have Storage as High Precision:
If the precision is not set as High, then you will need to run the Upgrade Spatial Reference GP Tool:
-Tim
