Worker Map - Android App - Fail to load updated Feature Service Data
833
10-03-2023 08:37 AM
ModernElectric
I have a project in Workforce that has background electric infrastructure hosted feature layers that are used by our field crew(s) for reference data. I also have a script created that updated the hosted feature layer from a file GDB created in ArcGIS Pro (Removes replicas, disables sync, truncates/appends data and enables sync). Script works fine. However, when the user of the project on an Android App version of Workforce needs to see the changes that were uploaded, before going into the project they have to "Reload" the project. When this happens, there is an error message that says the feature layer (that was just recently updated from the script) cannot be loaded. I have to go back into the Web Map and reload/reconfigure the feature layer for it to work. Any idea on why this is happening and/or what I can do to correct it? Goal is to run the scripts/batch files on the nightly basis so our field crews have up to date information.
Thank You
