I can make more of 100 assignaments on web enviroment
1402
08-17-2021 03:48 PM
JhonAlexanderAvendañoPaez
I can make more of 100 assignaments using python scripts for workforce
Reinaldo_Cartagena
Hi Jhon. If it is possible to load more than 100 assignments into a Workforce project. One way is to implement Toolbox with Scripts made with the Python API and upload an Excel file with multiple assignments. I have loaded more than 3,000 assignments using a Toolbox in ArcGIS Pro. Attachment sent the Python Sample Scripts.
Example 1:
import shapefile
import types
import pandas as ipandas
import arcpy
import traceback
import arcgis
from arcgis.gis import GIS
from arcgis.apps import workforce
from arcgis.geometry import Point
def loadData (portalConnection, username, project, itemtype, file):
# overwriteOutput
# List of assignments to add
records = []
# Read the asssigned from file and loop through the assignned information contained within this file
arcpy.AddMessage("Parsing ...")
arcpy.AddMessage(itemtype)
arcpy.AddMessage(file)
arcpy.AddMessage("Adding ...")
if itemtype == 'Excel File': # get item itemtype: 'Excel File' ...
item = ipandas.read_excel(file)
for index, row in item.iterrows():
# Create assignment in state 0-Unassigned
record = workforce.Assignment(project
,feature=None
,geometry=Point({"x" : row["POINT_X"],"y" : row["POINT_Y"],"spatialReference" : {"wkid" : row["Wkid"]}}) # Create assignment XY
,assignment_type=row["Tipo_asignacion"]
,status=0
,location=row["Direccion"])
# Update assignment attribute
record.assigned_date=ipandas.to_datetime(row["Fecha_asignacion"])
record.due_date=ipandas.to_datetime(row["Fecha_vencimiento"])
record.status=int(row["Estado"]) # state 1-Assigned
record.dispatcher=project.dispatchers.get(user_id=row["Despachador_id"]) # get dispatcher from user_id
record.worker=project.workers.get(user_id=row["Trabajadorcampo_id"]) # get worker from user_id
record.work_order_id=row["Identificador"]
record.description=row["Descripcion"]
record.priority=int(row["Prioridad"])
record.notes=row["Notas"]
# Set attachment
record.attachment_file=types.SimpleNamespace()
record.attachment_file=row["Anexo"]
# Add all assignments to the list created
records.append(record)
# Batch add assignments
batchAdd = project.assignments.batch_add(records)
arcpy.AddMessage(batchAdd)
arcpy.AddMessage("Adding Attachments...")
for assignment in batchAdd:
try:
if hasattr(assignment, "attachment_file"):
assignment.attachments.add(assignment.attachment_file)
except Exception as e:
continue
arcpy.AddMessage("Completed")
else:
arcpy.AddMessage('ERROR getting item from ... '+item)
arcpy.AddMessage("Load data "+itemtype+" completed")
return batchAdd
Reinaldo_Cartagena
OBJECTIDArea_TerrenoAvaluo_TerrenoDimensionEtiquetaRelacion_SuperficieIdentificadorObservacionesManzana_Vereda_CodigoVR_NPN_NUMEROPOINT_XPOINT_YPOINT_ZTipo_asignacionEstadoNotasFecha_asignacionFecha_vencimientoDespachador_idTrabajadorcampo_idPrioridadDireccionDescripcionWkidAnexo
8844289647Dim2D  0341001011003500001 0035050340100001100350001901000001-75.878480915.6593341190Visita_Inicial1Identificador: 0341001011003500001 - VR_NPN_NUMERO: 050340100001100350001901000001 - Area_Terreno: 4 - Avaluo_Terreno: 4289647- Dimension: Dim2D6/10/202120/09/2021rcartagena_gnjavendano_gn0Manzana_Vereda_Codigo:0035 - POINT_X=-75.878480912 - POINT_Y=5.65933411900005 - Wkid=4686Tipo_asignacion: Visita_Inicial - Estado: 1 - Despachador_id: rcartagena_gn - Fecha_asignacion:  - 44475 - Fecha_vencimiento: 44459 -  - Prioridad: 04686D:\Myprofile\Projects\Sectores\National_Government\ANT\PoC_Workforce_2021\Image_File\Anexo_1.jfif
8944289647Dim2D  0341001011003500001 0035050340100001100350001901000001-75.878480915.6593341190Visita_Inicial1Identificador: 0341001011003500001 - VR_NPN_NUMERO: 050340100001100350001901000001 - Area_Terreno: 4 - Avaluo_Terreno: 4289647- Dimension: Dim2D6/10/202121/09/2021rcartagena_gnjavendano_gn0Manzana_Vereda_Codigo:0035 - POINT_X=-75.878480912 - POINT_Y=5.65933411900005 - Wkid=4686Tipo_asignacion: Visita_Inicial - Estado: 1 - Despachador_id: rcartagena_gn - Fecha_asignacion:  - 44475 - Fecha_vencimiento: 44460 -  - Prioridad: 04686D:\Myprofile\Projects\Sectores\National_Government\ANT\PoC_Workforce_2021\Image_File\Anexo_2.pdf
9044289647Dim2D  0341001011003500001 0035050340100001100350001901000001-75.878480915.6593341190Visita_Inicial1Identificador: 0341001011003500001 - VR_NPN_NUMERO: 050340100001100350001901000001 - Area_Terreno: 4 - Avaluo_Terreno: 4289647- Dimension: Dim2D6/10/202122/09/2021rcartagena_gnjavendano_gn0Manzana_Vereda_Codigo:0035 - POINT_X=-75.878480912 - POINT_Y=5.65933411900005 - Wkid=4686Tipo_asignacion: Visita_Inicial - Estado: 1 - Despachador_id: rcartagena_gn - Fecha_asignacion:  - 44475 - Fecha_vencimiento: 44461 -  - Prioridad: 04686D:\Myprofile\Projects\Sectores\National_Government\ANT\PoC_Workforce_2021\Image_File\Anexo_3.jfif
9144289647Dim2D  0341001011003500001 0035050340100001100350001901000001-75.878480915.6593341190Visita_Inicial1Identificador: 0341001011003500001 - VR_NPN_NUMERO: 050340100001100350001901000001 - Area_Terreno: 4 - Avaluo_Terreno: 4289647- Dimension: Dim2D6/10/202123/09/2021rcartagena_gnjavendano_gn0Manzana_Vereda_Codigo:0035 - POINT_X=-75.878480912 - POINT_Y=5.65933411900005 - Wkid=4686Tipo_asignacion: Visita_Inicial - Estado: 1 - Despachador_id: rcartagena_gn - Fecha_asignacion:  - 44475 - Fecha_vencimiento: 44462 -  - Prioridad: 04686D:\Myprofile\Projects\Sectores\National_Government\ANT\PoC_Workforce_2021\Image_File\Anexo_4.jpg
9244289647Dim2D  0341001011003500001 0035050340100001100350001901000001-75.878480915.6593341190Visita_Inicial1Identificador: 0341001011003500001 - VR_NPN_NUMERO: 050340100001100350001901000001 - Area_Terreno: 4 - Avaluo_Terreno: 4289647- Dimension: Dim2D6/10/202124/09/2021rcartagena_gnjavendano_gn0Manzana_Vereda_Codigo:0035 - POINT_X=-75.878480912 - POINT_Y=5.65933411900005 - Wkid=4686Tipo_asignacion: Visita_Inicial - Estado: 1 - Despachador_id: rcartagena_gn - Fecha_asignacion:  - 44475 - Fecha_vencimiento: 44463 -  - Prioridad: 04686D:\Myprofile\Projects\Sectores\National_Government\ANT\PoC_Workforce_2021\Image_File\Anexo_5.jfif
9344289647Dim2D  0341001011003500001 0035050340100001100350001901000001-75.878480915.6593341190Visita_Inicial1Identificador: 0341001011003500001 - VR_NPN_NUMERO: 050340100001100350001901000001 - Area_Terreno: 4 - Avaluo_Terreno: 4289647- Dimension: Dim2D6/10/202125/09/2021rcartagena_gnjavendano_gn0Manzana_Vereda_Codigo:0035 - POINT_X=-75.878480912 - POINT_Y=5.65933411900005 - Wkid=4686Tipo_asignacion: Visita_Inicial - Estado: 1 - Despachador_id: rcartagena_gn - Fecha_asignacion:  - 44475 - Fecha_vencimiento: 44464 -  - Prioridad: 04686D:\Myprofile\Projects\Sectores\National_Government\ANT\PoC_Workforce_2021\Image_File\Anexo_6.jpg
1249810615794Dim2D  0341001011003500002 0035050340100001100350002000000000-75.878613735.6592033830Visita_Inicial1Identificador: 0341001011003500002 - VR_NPN_NUMERO: 050340100001100350002000000000 - Area_Terreno: 98 - Avaluo_Terreno: 10615794- Dimension: Dim2D6/10/202126/09/2021rcartagena_gnjavendano_gn0Manzana_Vereda_Codigo:0035 - POINT_X=-75.87861373 - POINT_Y=5.65920338300003 - Wkid=4686Tipo_asignacion: Visita_Inicial - Estado: 1 - Despachador_id: rcartagena_gn - Fecha_asignacion:  - 44475 - Fecha_vencimiento: 44465 -  - Prioridad: 04686D:\Myprofile\Projects\Sectores\National_Government\ANT\PoC_Workforce_2021\Image_File\Anexo_7.docx
125889532549Dim2D  0341001011003500004 0035050340100001100350004000000000-75.87871355.6590997030Visita_Inicial1Identificador: 0341001011003500004 - VR_NPN_NUMERO: 050340100001100350004000000000 - Area_Terreno: 88 - Avaluo_Terreno: 9532549- Dimension: Dim2D6/10/202127/09/2021rcartagena_gnjavendano_gn1Manzana_Vereda_Codigo:0035 - POINT_X=-75.8787134999999 - POINT_Y=5.65909970300004 - Wkid=4686Tipo_asignacion: Visita_Inicial - Estado: 1 - Despachador_id: rcartagena_gn - Fecha_asignacion:  - 44475 - Fecha_vencimiento: 44466 -  - Prioridad: 14686D:\Myprofile\Projects\Sectores\National_Government\ANT\PoC_Workforce_2021\Image_File\Anexo_8.xlsx
