Updating Job STATUS thru REST API FAILS
2189
08-21-2013 06:27 AM
RobinBoyle
I am trying to update the status of a JOB thru the REST API by using the Update REST endpoint; however, this keeps failing...
Example:
http://<myserver>/arcgis/rest/services/Workflows/QuickStart_WorkflowManagerService/WMServer/jobs/job/1009/update?f=json&properties={???status???:23}
???where 23 is the OOTB status of ???Working???.
I get the following error:
{???error???:{???code???:400,???message???:???Access denied.???,???details???:[]}}
Does this infer permissions?  I have UpdateProperties permission on this user, but is there another that I need?
Workflow Manager for Server 10.1...
Many thanks in advance!
Robin
RobinBoyle
MORE INFO:
I also added the &user=myuser to the REST URL.  (Obviously 'myuser' isn't the actual value I used...)
http://<myserver>/arcgis/rest/services/Workflows/QuickStart_WorkflowManagerService/WMServer/jobs/job/1009/update?f=json&user=myuser&properties={�??status�?�:23}
This returned a result of "success": "true".  BUT the database table never gets updated...
Robin
Example:
http://<myserver>/arcgis/rest/services/Workflows/QuickStart_WorkflowManagerService/WMServer/jobs/job/1009/update?f=json&properties={�??status�?�:23}
�?�where 23 is the OOTB status of �??Working�?�.
{�??error�?�:{�??code�?�:400,�?�message�?�:�?�Access denied.�?�,�?�details�?�:[]}}
Robin
KevinBedel
Hi Robin,
This is a known issue with ArcGIS 10.1 Workflow Manager for Server. It has been resolved with ArcGIS 10.2 Workflow Manager for Server.
Kevin
