Step [A] on Job [X] was not updated. The specified step is currently running.
1097
08-01-2023 06:49 AM
Ranga_Tolapi
ArcGIS Workflow Manager: Version 10.9.1
High-Availability Enabled: Yes (2 Nodes)
OS: Windows Server 2022
Today (01-Aug-2023) experienced below error with a Step, job is unable to proceed further.
<Msg time="2023-08-01T16:21:12,984" type="SEVERE" code="9999" source="WorkflowManager" process="13332" thread="19" methodName="" machine="<FQDN_OF_WFM>" user="" elapsed="" requestID="">
! @82df88kdn - Internal server error, for (POST) [/workflow/8c15153a74f749328ba775b2bc9ae837/jobs/lAvQ4-57TeGCbeA6hRWetw/c1f4e242-4a2f-192d-986e-2b6300a0ddd5?token=VxjQf1gU4FOp04JKZMUMNy_3dvHOAP5Q..] -&gt;
play.api.UnexpectedException: Unexpected exception[WorkflowAssignmentException: Step c1f4e242-4a2f-192d-986e-2b6300a0ddd5 on Job lAvQ4-57TeGCbeA6hRWetw was not updated. The specified step is currently running] at play.api.http.HttpErrorHandlerExceptions$.throwableToUsefulException(HttpErrorHandler.scala:355)
Caused by: esri.workflow.exceptions.WorkflowAssignmentException: Step c1f4e242-4a2f-192d-986e-2b6300a0ddd5 on Job lAvQ4-57TeGCbeA6hRWetw was not updated. The specified step is currently running at esri.workflow.controllers.JobsController.$anonfun$assignStep$18(JobsController.scala:998)
</Msg>
Already applied ArcGIS Workflow Manager Server 10.9.1 Patch 3 in the month of Jun'23 in both the WFM machines.
This issue is happening with various steps, including the Question step. There is no specific pattern was noticed so far with this issue.
@JFarmer  please advise.
Ranga_Tolapi
Any expert advise on this please.
Olivit
Hello! Any advice about this issue?
Same error here with WFM v10.9.1 in HA on Linux RHEL 8.4
Tulasiram7
Any Solution I am also facing same issue, I have Triggered a GP Tool from workflow manager and i have cancelled the job from ArcGIS server, the workflow manager step gone into running state, even when i cancel the step from WFM, I can see play button but which is still in running state, i cannot assign or delete or force stop the step, this is bit frustrating.
