Exception after creating Recurring job in WFM
706
07-25-2022 07:28 AM
sirishb
Hi All,
ArcGIS enterprise version: 10.9.1
We are using ArcGIS Workflow Manager Server (service-driven). We have created simple workflow diagram to send Email and scheduled the same as "recurring Job" in template.
Job schedule is set to 1Hr 15min.
After 1Hr 15min, in portal appearing one notification.
We have verified the "Tasks" under "ArcGIS portal directory" and the following exception it is showing.
java.lang.Exception: Exception: PKIX path building failed: host unable to find valid certification path to requested target
CA certificate is configured in IIS.
Appreciate any help on this. Thanks.
JFarmer
JFarmer
Hi @sirishb
Can you import your CA cert into Portal Admin? This is likely the cause.
https://enterprise.arcgis.com/en/portal/latest/administer/windows/import-a-certificate-into-the-port...
Jonathan
