Displaying Jobs with Overlapping AOI
1680
10-11-2012 05:39 AM
MikeJohnson2
Greetings,
Is it possible to display jobs with overlapping AOIs?  For example Job 1 has a large AOI that fully encompasses Job 2, Job 2 is not visible on the map.  If it is possible to display both jobs what are the steps required to display Job 2 in the example?
Mike
AlisonGaiser
Mike,
Maybe this is too simple, but could you modify the map document that is being used by the AOI Base Map for the Job and change the symbology for the JTX_JOBS_AOI to be hollow or to have a transparency? Or do you mean the Map View in the Workflow Manager? If that is the case, could you do the same thing but in this case change the map document that is being referenced under System Settings, Map Views, Job Result Map View?
Alison
AlisonGaiser
Mike,
Alison
