AOI is not defined
3286
09-08-2010 06:18 AM
MarcoWagemakers1
After installing and the configuration of workflow manager 10 there is a message "AOI is not defined".. I don't know exactly the problem, because the first step of my workflow is JTXDesktopSteps.DefineAOI.
Marco
TopeBello
Once you execute the define AOI step and draw an area of interest using the engine control presented to you, this should update the job property. Can you click another job in the list view, because this might be an issue that it does not refresh?
Also, you can try using the AOI tab to define an AOI. Remember to save when you use the AOI tab and see if that property gets updated.
Tope
MarcoWagemakers
Oh thanks, I forgot to "save". It works now fine...
