Widget for resetting a column of a related table
725
09-09-2022 09:18 AM
ttamba
I'm looking for a Widget allowing me to reset a column of assets whose value is "inspected".
I configured a map with WebAppBuiler that uses a related table and feature layer available in AGOL from a municipal asset inspection application, configured in ArcGIS Field Maps.
I would like to be able to do the following action:
  • Reset the 'Inspected' value to 'Null' of the "Status" column from the attribute table, once all the assets are inspected in order to allow the inspection of the next schedules.
Thank you in advance for any suggestions and feedback on this case.
Kind regards,
ttamba
Since my question seems to be impossible to resolve using customed widget, is it any options or workarround to adresse this issue using AGOL?
This can be achieve using ArcGIS Pro and Field Calculator. But since, this task is accomplished by non GIS users, the best way is to configure a webapp to allow them to accomplish this task...
Regards,
