Widget Deployment Issue
5123
15
12-19-2016 09:46 AM
JeffDavis2
Hello.  I am new to the post and web appbuilder and I am hoping this is a very easy fix.
I recently downloaded a custom widget from this site.  I unzipped the widget and copied its corresponding file folder over to the 2D location \client\stemapp\widgets.  Unfortunately, when I open a web application I am currently working on the widget does not appear in the selection.
What am I doing wrong?
Thank you in advance.
JeffDavis2
Thank you, Robert for all your help!  Perfect!
Jeff
JeffDavis2
Sorry I did not answer your question...I did not download the widget from GitHub.
I downloaded it from this site...GeoNet.
RobertScheitlin__GISP
Jeff,
   I'm pretty sure you did not mean to mark your reply as the correct answer so I un-marked it.
JeffDavis2
Thanks, Robert.
Newbie...what can I say.
I'll mark your response.
Jeff
RebeccaStrauch__GISP
Jeff, you may want to mark Robert's responses that helped too, since there is more than one response that lead to the end solution.This helps others in the future. Just a suggestion.
JeffDavis2
Got it.  Thank you for the correction.  After this, I should be a pro.
