When app state is used, ellipse (...) symbol shows twice in popup.
1788
10-28-2016 06:22 AM
ChristopherSchreiber
Hello,
We have an app that was created with WAB 2.1 DE hosted on our web server. Whenever I use the "App State" box to return to my last extent on the app, this causes the ellipse (...) symbol to appear twice on the popup window for a feature. How do I get rid of the second ellipse?
Thanks!
RobertScheitlin__GISP
Christopher,
   Great catch. I have not noticed this bug before. You should call it into esri tech support as it looks like 2.2 will have this issue as well.
Here is the workaround you can apply to fix this though:
In the [install dir]\jimu.js\PopupManager.js replace the _createPopupMenuButton function with this one:
      _createPopupMenuButton: function(){
        if(query(".popup-menu-button", query(".actionList", this.popupUnion.bigScreen.domNode)[0])[0]){
          html.destroy(query(".popup-menu-button", query(".actionList", this.popupUnion.bigScreen.domNode)[0])[0]);
        this.popupMenuButtonDesktop = html.create('span', {
          'class': 'popup-menu-button'
        }, query(".actionList", this.popupUnion.bigScreen.domNode)[0]);
        var mobileActionListNode = query(".esriMobilePopupInfoView .esriMobileInfoViewItem").parent()[0];
        if(query(".esriMobileInfoViewItem", mobileActionListNode)[0]){
          html.destroy(query(".esriMobileInfoViewItem", mobileActionListNode)[0]);
        var mobileViewItem = html.create('div', {
            'class': 'esriMobileInfoViewItem'
          }, mobileActionListNode);
        this.popupMenuButtonMobile = html.create('span', {
        }, mobileViewItem);
        on(this.popupMenuButtonDesktop, 'click', lang.hitch(this, this._onPopupMenuButtonClick));
        on(this.popupMenuButtonMobile, 'click', lang.hitch(this, this._onPopupMenuButtonClick));
Junshan Liu
Christopher,
        }, mobileViewItem);
Junshan Liu
Thanks Robert!
I will call Esri about this.
Chris
Just to Update,
I contacted Esri Support about this issue and a bug was created.
Bug Number: 000100499
In Web AppBuilder, an extra set of ellipses appears in pop-ups when using the 'App State' feature to return to the last extent of the application before it was closed.
Chris
