Webapp Builder: How to limit and rename fields in "export to CSV" within the query widget?
995
10-20-2021 09:25 AM
CalebWilliams2
I'm using the export to CSV option to allow my users to generate reports based on whatever they query, but whenever the csv is generated it follows the formatting of the underlying data. Is there any way to have the fields that show up in the csv mirror the fields that show up in the pop-up?
ABishop
@CalebWilliams2
The solution would be to customize the attribute table and hide fields you don't want visible.  You do this through the attribute table widget settings.
Amanda Bishop, GISP
