WebApp Builder 2.3 - Restrict feature action options
2827
03-28-2017 09:46 AM
OverlaysS
Is there a way to restrict the feature action options in WebApp builder?
WebApp Builder 2.3 enables widgets to cross-interact with each other using feature actions.  For example - the default pop-up  can be used to set a feature as input to geoprocessing widgets;  the "SELECT" widget also gives the option to use selection as input to geoprocessing tools.
I have three geoprocessing widgets in my application and they all appear as feature action options in the  pop-up and SELECT widget options. I want to ideally be able to either disable any geoprocessing tool of choice or disable all of them.
I tried deleting the feature action setting in the app config.json but no success. I have also taken a look at the FeatureActionManager.js and BaseFeatureAction.js file (located in the jimu.js folder) but no luck.
Any suggestions/pointer will be appreciated.
Thanks
Offie
JeremyWolff
Hi Offie,
Have you found a solution for that so far? I am also trying to remove a few feature actions in the query result, come of which appear twice (see in the photo attached).
I look in the same files as you (FeatureActionManager.js and BaseFeatureAction.js file) but no luck.
Let me know what you have found.
Cheers,
Jeremy
PS: The enhaced search widget from Robert Scheitlin, GISP‌ does not have this issue:
#querywidget#customwidget‌
