Web App Builder Widget Spacing Issue
2272
6
04-23-2020 07:52 AM
joerodmey
Using WAB dev edition. My widgets seem to be spacing out incorrectly at certain screen sizes.
Here is the config.json:
Any ideas?
RickeyFight
joe rodmey
You need to change all 4 of the "left":   lines until you get the desired location.
RickeyFight
joe rodmey
Can you provide some screenshots of what you are seeing?
joerodmey
See inlcuded
RickeyFight
I believe its your
"position":{
   "left": 45,
You have a space of 100 from the select to the query but the other ones are 45 and 55 so only 10 px spacing which is why they overlap
joerodmey
Si I need to change the 45?
RickeyFight
joe rodmey
joerodmey
It worked. Thanks!
