Web App Builder Geoprocessing Buffer Widget.
1826
11-23-2020 06:26 AM
OmarJaved
Hi All,
I've been trying to add a buffer widget through a geoprocessing script in my web app builder. This does seem like a minor issue but I'm stuck on how to resolve it. The tool works fine and an output is generated but it seems I can't check/uncheck which fields to display in the output, or give them aliases, change the order etc. When I do that it simply reverts back to the default. settings.
I made the model using the buffer, intersect and summary stat tools. Seems like a simple problem but I'm clueless on what to do.
LefterisKoumis
Did you set the outfields in your query?
OmarJaved
Yeah I set them in the summary stat tool. Initially dissolved them in the
buffer then used the same feature class to intersect to get the fields
back.
