WAB dev edition Sample Widget default services
1989
08-15-2016 12:22 PM
Alexwang
HI, got message below when using WAB dev edition. I can browse the service via rest url, but it said the services are not available. Can anybody tell me how to change these services (911CallHotSpot and Wildlife) behind so i can use my services? Thanks,
Tags (1)
RobertScheitlin__GISP
Alex,
   It is the webmap that that json is calling that has those urls. So if you want to fix that then you need to modify the config-demo.json and change the maps itemId to one of your own web maps.
Alex,
  What sample widget? can you give more details?
Alexwang
Robert, the default web map when I was testing via http://mycomputer:3344/webappviewer/?config=sample-configs/config-demo.json
I am using WAB dev edition 2.0
Alex,
Alexwang
Thanks Robert. you helped!
