URL parameters zoom level
1734
04-11-2019 10:43 AM
ScottThomas1
I'm using URL parameters to select to a polygon on open but the zoom level is usually 1 level to close. Is there an easy way to back it off?
WAB Dev. 2.11
RobertScheitlin__GISP
Scott,
The only way you can fix this is to modify the MapUrlParamsHandler.js file selectFeatures method. Where it does the map.setExtent.
Scott,
ScottThomas1
I see that around line 400 but it isn't clear how to make an adjustment. I was hoping it was a simple zoom level but it looks like the extent sets a minx & y etc.
Scott,
   You just use the extent classes expand method. i.e.
map.setExtent(resultExtent.expand(1.2, true));
ScottThomas1
That worked great. I pushed it out a little more even. As a mapper dabbling in code, I really appreciate the help you offer here.
