Unwanted fields when exporting to csv
835
06-01-2021 12:46 PM
Labels (2)
RandyMcGregor3
I have set up some layers in a web app that have a very specific set of fields because the output will be used in an app that requires certain fields - and won't work if there are any more - they need to be removed first.
I select features with the selection widget then either export from the selection widget panel or open the attribute table and export to csv. The following fields get added:
OBJECTID - Turned off in web map
SHAPE - Turned off in web map
wkid - Not in the original attribute table
x - Not in the original attribute table
y - Not in the original attribute table
Is there any way to exclude these fields? I am willing to take a crack at web app builder for developers.
Thank you,
Randy McGregor
