Unable to access web app once deployed
2124
10-03-2014 05:19 PM
GrantHerbert
Using the 2.0 Beta of the ArcGIS Web App Builder
I created an application on my local machine using an ArcGIS Online web map and I can view this using the Launch button in the web builder.
Then I download the application and deploy it on my local server, as per the documentation. Register the application with ArcGIS Online and share with my organization. Using the instructions I replace the appId in the config file with the newly registered appId.
I can sometimes load the map from my local server, but the widgets fail to load. If I check the traffic I can see that launching the app from the builder uses /webappbuilder/apps/..., launching it from my site it uses /appbuilder/TestPCARViewer/.. which is the folder that I have it in. Except that some of the widget config files are still looking for the webappbuilder url.
eg
/appbuilder/TestPCARViewer/widgets/LayerList/LayerListView.html
then a little later:
/webappbuilder/apps/2/widgets/LayerList/config_LayerList.json
And I cannot see my layer list.
IE 11 and Chrome both exhibit the same behaviour.
Unsure where to start debugging this, any suggestions?
