Query widget - add image to results
1560
01-27-2020 10:06 AM
ChantellKrider1
I’d like to display an image in the Query Widget results window (pictured attached.
I can get the image to display in the pop up in the web map, but for some reason it won’t display in widget.
Here’s my Arcade for the image:
/*Up Legend – Regular Block Group*/
Iif($feature["UP_Eligibl"]=="Eligible", "https://rco.wa.gov/wp-content/uploads/2020/01/MatchMapUnderservedLegend.png","")
BenTurrell
Hey Chantell,
How are you trying to add the image? If you use the expression you have written in the html source part of the pop up contents then that should work.
You would have something like this in your html source:
<img src="{expression/expr0}">
Ben
If this answer has helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
BenTurrell
Hey Chantell,
Ben
ChantellKrider1
Yep. That was it! Thank you!!
