Problem with Zoomgrid Widget
1185
01-27-2019 11:58 AM
Ángel_DanielSuárez_Calero
Hi friends, I have a problem with Zoomgrid Widget. I used this widget with a polilyne shapefile, this widget works correctly for a lot of polylines but some of them doesn´t work correctly. I recive the message :
"Cannot read property 'geometry' of undefined". I tried "zoom to feature" in ArcGis Pro with the same polyline and it works correctly , but this reason I think that my shapefile is correct and I don´t know why I have this problem whit the Widget.  Has anyone had this problem with Zoomgrid Widget?
Regards and Thanks!
RobertScheitlin__GISP
Angel,
   The ZoomGrid was just an example of how to port over a JS API sample to a widget and was never meant to be a widget that I support.
dgrid in side panel with zoom to function
Tyler,
  Here is a quick port of that JS API sample to a WAB Widget that you can learn from.
You will have to debug to see why the ObjectID for those polylines are having an issue.
Angel,
Tyler,
Perfect, I thank the same, I tried using other field in the widget , and every attributes worked correctly. The problem was in the shapefile.
Thanks for everything once again Robert!
