probem related ti congiguration of offline setup if ArcGIS web app builder developer edition
829
10-22-2024 11:51 PM
WaniaIshtiaque
Basically Im working on a task where I have to make an offline map which has following characteristics ,
1- Can be zoom in and zoom out
2- pan
3- Add layers
4- toggling of layers
5- search location
6- upload external URLs and files
While I was successful in creating the required demo map on the ArcGIS online using web app builder , I even downloaded it
Now the map is available online but I want to make it work offline and for that reason , I searched and come up with the idea of using ArcGIS web app builder developers , I found a video tutorial and was following I did everything according to it  but when Im going to register my app Im getting Credentials options instead of app registration inside that credentials I found an option of register your application I filled the form but after completing Im getting the client ID , client secret and temp token , instead of App ID
Well I treated client ID as App ID just to check and inserted it as the app ID but after sign in permission it is giving me an error of
ArcGIS Portal Directory
Error
Invalid redirect_uri
Error: 400
I even deleted the signin.info json file and repeated the whole process ,its been days and Im still stuck at this part, please keep in mind Im very new to ArcGIS and is exploring new things , please guide me with making my concepts correct.
