Pop-up hyperlink to local network in Portal for ArcGIS
6351
8
03-28-2019 06:56 AM
AriLukas
I am working in ArcMap 10.5 and published a feature service to the Portal for ArcGIS. One of the features layers I have published has a field which contains a hyperlink to a folder on our local network.
Is there a way to enable and click the hyperlink in the pop-up window that will access the folder  on our local server?
Dr__Nadia_AsadSiddiqui
I published a feature service in arcmap 10.6.1 to ArcGIS portal, and I want to show the hyperlinks associated with  the published service in Web map created through Web App builder, but in vain. Can anyone help?
RobertScheitlin__GISP
The hyperlinks have to be a valid publicly accessible url like http://www.google.com and can Not be a network path. A network path will work in the desktop environment but is not appropriate for web apps.
Is there a way out (a custom widget) to show the respective pdf files of my point feature layers in the Web app, by clicking on respective point features?
No it is not an issue with a particular widget, it is an overall issue with modern browsers and not being able to use network drive paths directly in web applications. It is very simple for your IT  people to setup a virtual directory so that you can have an actual url instead.
KennethBusby
I am trying to access Property cards in a folder using a path like this File:\\ServerName.Domain.local\foldername\filename.pdf
it will not open the link even though chrome will open the file if you copy and paste it into the browser.
I am not sure what I am missing.
Ken
Kenneth Busby
I had the same problem and it finally resolved by copying the folder (that contain the files you want to open through hyperlink) to the C://intepub/wwwroot directory.
For example my folder name was SMS_HPL (it contained all scanned maps as pdf files)
My server name is main-gis-01.abc.com
the file I want to access though html popup is Misal_Colony_DistributionMap.pdf
so, the path is https://main-gis-01.abc.com/SMS_HPL/Misal_Colony_DistributionMap.pdf
Make sure you configured the popup window in your web map.
Hope it will work.
Nadia
KennethBusby
the server the files are on is not a web server with that directory. does it have to be on a webserver?
KennethBusby
Thank you I was able to move it to a webserver and it worked. Thank you!
