Need Help With Solving An Issue Of Testing A Custom Widget
1910
6
12-06-2019 12:51 PM
SamLee1
When testing my custom widget, this link: https://........./webappbuilder/?id=2 will not refresh my custom widget with it's new features that I implemented. But this link does: https://.............:3344/webappviewer/?config=sample-configs/config-demo-MyWidget.json. Why is that the case? How can I test it with the first link?
RobertScheitlin__GISP
Sam,
  Sounds like you may be in the same boat as this user the other day. See my reply to his post.
https://community.esri.com/thread/244945-web-app-builder-has-horrible-experience
Sam,
SamLee1
Hello Robert,
I have read your response. Is that where you are supposed to be developing your custom widget?
That is one correct workflow method (that I prefer).
SamLee1
Which is the main way people use to develop a custom widget?
That's hard to say without polling a sample group. But lets just say as the owner of the Web AppBuilder Custom Widgets space and the largest contributor of custom widget, you are safe to use my preferred method.
KenBuja
MVP Esteemed Contributor
Another way to develop a widget is to use the tools and methodology available here:
GitHub - Esri/generator-esri-appbuilder-js: Yeoman generator to help customize Esri's WebAppBuilder
Most of this is about generating all the files and directory structure for a widget, but it also talks about keeping your widget edits synced up with your app (see "Running the Grunt Tasks" section).
