Need Help Understanding A Made Custom Widget
1790
12-19-2019 03:05 PM
SamLee1
I am looking through GitHub resources to see if I can get a better understanding of creating custom widgets. I came across this GitHub and was confused on the service that he used. He is able to use a service that brings in data from Minnesota counties and display them. What service is that? I am trying to mimic his widget to my own. For example, I want to zoom into cities within the Sacramento County and display a result just like what he did. This is confusing me a lot. I am trying to understand his logic of using that service. Like how is he getting the data and where? Is it a service made already by Esri?
Here are his links:
2018GISLIS/widget2.md at master · paulhedlund/2018GISLIS · GitHub
2018GISLIS/widget3.md at master · paulhedlund/2018GISLIS · GitHub
I have attached his widget for visual and code reference.
RobertScheitlin__GISP
Sam,
  He is using a WebMap with an id of f52b53780bde41e0b8e6c695f64199e4
https://www.arcgis.com/home/item.html?id=f52b53780bde41e0b8e6c695f64199e4
That web map uses this layer:
https://services.arcgis.com/8df8p0NlLFEShl0r/arcgis/rest/services/MN_Counties_New/FeatureServer/0
You can find the above url by looking at the web maps layers and then the layers service url.
Sam,
SamLee1
Hello Robert,
Thanks for the response.
Do you know how I can find those services for Sacramento County and its cities within that county?
Sam,
  Sure just search www.Arcgis.com
https://www.arcgis.com/home/item.html?id=a2f3193ea0884afe8a8231902d638fd8
Or get data from the open data website for your county.
Sacramento County GIS Open Data Site
