Nearme - Display search and results separatly
684
06-16-2020 11:00 AM
by Anonymous User
Not applicable
Hi!
I'm using the Nearme widget. When the application is used with a computer, it works well. However, on a Iphone, the widget isn't responsive and less intuitive.
I would like to display the search bar and the results separately. In other words, once the adress is enter in the search bar and the search is lauch, it will disapear showing only the results (see picture).
This would reduce the range of the widget on the screen (by default is like 50% of the screen) to see more of the map.
Or if you know where to go in the code to change the width of the widget (panel) . It's probably easier this way.
Thank you!
Tags (3)
