layers out of range greyed out
22558
42
07-01-2015 01:51 PM
AmyKlug
out of visibility range layers do not grey out in the webapp builder layer list widget, can this be changed programmatically?
FrankVignati
the newer version of LayerListView from 1.3 differs at line 175/176
ckSelect = new CheckBox({
checked: layerInfo.isVisible(), //layerInfo.visible
'class': "visible-checkbox-" + layerInfo.id
does the newer syntax need to be added?
RobertScheitlin__GISP
Frank,
  Here is a 1.3 version
FrankVignati
THANKS!
ColeAndrews
Robert-- Just plugged the 1.3 version in and noticing a small issue or two. One feature service in the map has 5 layers. All 5 layers have the same visibility extent setting. When zoomed to that scale, all the layers display on the map as they should, however two of them are greyed out as if not visible. I can still toggle them off and on and the map responds appropriately. I confirmed in ArcMap that the visible scales are the same for all layers. Any idea if this is something that needs fixed on my end?
Cole,
   I have done some testing and I can not reproduce this.
RyanKelso
It's been a few months since Cole's post, but I'm curious if this was his problem:  With this modification, the first time you open the Layer List widget, all layer names inside of a map service appear grayed out until you zoom in or out.  After that everything behaves as expected.
Ryan,
  See this reply for a fix to that: https://community.esri.com/thread/161457#comment-549382
RyanKelso
Thank you!!  This has been annoying me for so long, I can't believe the fix was right there!  D'oh!
by Anonymous User
Not applicable
works in 1.2. PERFECT.
All,
  Here is the 2.0 version with a more ArcMap like feel to it (i.e the scale image on the checkbox).
