In pop up window, Add Hyperlink to http pdf in the attribute table
460
06-30-2022 01:45 PM
L77
I added the DNR forest practice application data to my web map, and am configuring the pop up window.
I can't get the pdf links to work.
Here is a screenshot of the forest practice application web app, so I know it can work:
The links in the attribute table work great:
It works if I use the setting a list of field attributes. It doesn't work when I use a custom display of attributes.
Here is one of the links:
It has the last 3 numbers of the FP_ID in the link, then at the end of the link it lists the whole FP_ID twice.
https://fortress.wa.gov/dnr/fparsimages/apps818/fp2933818/fp2933818.pdf
Here is one attribute in the table: the link is in the PDF_LOCATION field.
SHAPE.LEN3870.574435
OBJECTID53955
FP_ID2902855
HARVEST_UNIT_NO1
TIMHARV_FP_TY_LABEL_NMRIGHT-OF-WAY
TIMHARV_RPT_AREA2.3
REGION_NMPACIFIC CASCADE
RECEIVED_DT36696
DECISION_DUE_DT36701
EFFECTIVE_DT36701
EXPIRATION_DT37431
RENEWAL_DTNull
JOB_POSN_NO1554
FP_JURISDICT_NMNull
CLASSIFICATIONII
ALTERNATE_PLAN_FLGN
CUTTING_OR_REMOVING_TIMBER_FLGY
AERIAL_CHEMICAL_SPRAY_FLGN
DECISIONAPPROVED
PDF_LOCATIONhttps://fortress.wa.gov/dnr/fparsimages/apps855/fp2902855/fp2902855.pdf
SHAPEPolygon
TEN_YEAR_PLAN_FLGN
UNSTABLE_SLOPE_FLGN
SHAPE.AREA55970.75
