I have a feature class with numerous polygons on an arcgis online map, which is also used in a Web Application Builder app v2.3 as a service. Each polygon has its on weblink(hyperlink) field that I used in arcgis online configure popups which allowed the user to click on the map and from the popup window click the hyperlink. Has the new March update to arcgis online changed the way hyperlinks are created. Link 1 image shows how the popup was and link 2 image is showing a new popup configuration. If I have a map service of over 200 polygons and each polygon has its own field with a hyperlink how do I add in to an online map and web application builder?
