How to show ALL points in a Chart Widget (Line)?
2311
12-17-2020 03:32 AM
GerardMartin
I have modified Chart Widget (line style to weight = 0) to get a ScatterPlot showing only points not lines.
Surprisingly, although I can access to complete serie of point vector, Chart widget ONLY show points for those fields that are shown in canvas. I have inspected widget.js code but I can not find where is the property or filter that manage this behaviour for visualizing points.
Any idea or suggestion would be appreciated. Thank you !
As a example, in the following chart you can see points with tooltips that are not shown by default and I am trying to show in chart by default not only with Tooltip function.
RehanChaudhary
@GerardMartin were you able to find a solution to this. I am also having the same issue and cannot find  the solution
GerardMartin
Hi @RehanChaudhary,
No, my original question was related a beta project to analyze some widgets functionality looking for easy customization to user demands. In my case, the conclusion was, most of then you have to develop by yourself.
RehanChaudhary
@GerardMartin so did you modified the code for chart widget itself or did you created you own widget from scratch to show a scatter plot?
GerardMartin
I modified the code for chart widget but I'm not a JS developer ... If you are, you can find lots of JS libraries with plot functionalities to create your own widget.
RehanChaudhary
Would it be possible for you to share the code snippet where you do it?
Currently i am unable to do it and i am also unable to show the labels for
both axis. Probably that might help
