Hello. Using Web AppBuilder Developer Edition, I put together a custom web app that I would like to publish to my organization's Portal, but I'm not sure how exactly to do so. I've read through the guide and a number of threads here on GeoNet, but I'm still not sure how to properly publish the app. I'm a novice when it comes to web development and servers and the like. Step 2 in that guide ("Deploy it on your web server") is a bit short on details, and I'm not sure if the instructions in this thread apply in my situation, since I'm only looking to publish the app on Portal for people within my organization to access.
Through some trial-and-error (and referencing documentation such as this), I found that in Portal I could view a template I downloaded by dropping the extracted folder in Portal's "apps" directory on the server and adding an application with its URL (e.g. https: //<server name>/arcgis/apps/BasicViewer/index.html) in Portal's web interface ("My Content"). Following the same basic process, I tried to publish an app that I created in Web AppBuilder Developer Edition. What I did was:
Downloaded the app from the Web AppBuilder Developer Edition interface
Put the extracted folder in Portal's "apps" directory on the server
Added an application in Portal through the "My Content" page
Put the app's URL under Data Source in Web Mapping Application Settings
Registered the app and put the App ID in the the app's config.json file
Set the redirect URIs to http: //<server name>:[port] and https: //<server name>:[port]
The app seems to load in Portal. It prompts for login to view the map, and if I change the data source URL at all it returns an error ("Page not found"). The problem I'm having is that when the "Request for Permission" window pops up and I click "Approve", the window goes blank and just hangs there.
I feel like it might be an authentication/configuration issue, but maybe I'm way off track. Any input would be much appreciated!
Hi Stephen,
You're on the right track. Try the following:
Hi Stephen,
Hello Jake,
Thank you for the quick reply—that is exactly what I needed! The app is now up and running on my organization's Portal.
Hi Jake, thank you for the reply. I tried upload an app to my portal but I don´t understand the part of "URL".
What It Is "webserver1" ? my portal url?
Thanks!!
Ángel Daniel Suárez Calero the "webserver1" is the name of the web server. For example, if your server where IIS installed is called gis.esri.com, and you copied the application files to a folder called testwebapp within the C:\inetpub\wwwroot folder, the URL would be: http://gis.esri.com/testwebapp
Hi Jake, thanks for all, I tried this but I recieved the next message : "The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable". My purpose is to host my app in my portal after developing it in "Wab". This is possible?
Thanks Jake!!
Best Regards!
You won't be able to host your application in Portal after it's developed with WAB Developer Edition. You will need to host the application on a web server, but you can then 'reference' the web application so that it's discoverable within your Portal.
Perfect Jake, thank you very much for your help, I have managed to see my application as an item in Portal with the IIS of my Portal server. Greetings and thanks!!
Hi Jake,
I downloaded the app from the Web AppBuilder Developer Edition interface 2.11
Put the app's URL under Data Source in Web Mapping Application Settings that is http://MyserverName/MyAppName/ which is hosted in IIS.
Registered the app in my setting App registration and Set the redirect URIs to http: //MyserverName.org.ca:80 and https: //MyserverName.org.ca:443
Took the App ID from App Registration section.
Opened the my application hosted in IIS and opened the app's config.json file and added the appid  and saved.
When i try to browse the application hosted in IIS. It keeps loading and nothing comes up.
Could you please advice where am i going wrong in the process.
Also as per Stephen summary above there is a suggestion for:
Not clear where it needs to be added.
What exactly i need to do to get my application working.
Thanks!!
Kafil Baig you should just have to
You should then be able to access the application by going to http://webservername/foldername
