How to extend Select widget?
972
08-13-2024 11:45 PM
LuisanaIG
Hello!!
I would like to extend the action menu from the Select Widget by adding the option to export in KMZ. But I can't find the way to do that modifying the code.
Someone have any idea?
Thank you!!
Laura
by MVP Regular Contributor
Looks like export to KMZ may not be supported. Look here to find some workarounds: https://community.esri.com/t5/web-appbuilder-custom-widgets-questions/how-to-export-from-wfs-to-shp-...
You can get this done in map view classic: https://doc.arcgis.com/en/arcgis-online/analyze/extract-data.htm
