How to Clear Search Widget from a Custom Widget ?
1493
02-14-2019 01:33 PM
by Anonymous User
Not applicable
We are working on a Custom Widget.
How do I clear the "Search  Widget" (Green)  from a  Custom widget(Red).
Attaching a snap.
I tried this code.
var widgets = this.appConfig.getConfigElementsByName('Search');
if (widgets.length > 0) {
debugger;
RobertScheitlin__GISP
Muralidhar,
   You will need to get a reference to the search widget from your widget. for that you will need add 'jimu/WidgetManager', to your widgets define array.
Then add this new helper function:
    _getWidgetConfig: function(widgetName){
      var widgetCnfg = null;
      arrayUtils.some(WidgetManager.getInstance().appConfig.widgetPool.widgets, function(aWidget) {
        if(aWidget.name == widgetName) {
          widgetCnfg = aWidget;
          return true;
        return false;
      if(!widgetCnfg){
        /*Check OnScreen widgets if not found in widgetPool*/
        arrayUtils.some(WidgetManager.getInstance().appConfig.widgetOnScreen.widgets, function(aWidget) {
            return true;
          return false;
      return widgetCnfg;
And call this code:
      var widgetCfg = this._getWidgetConfig('Search');
      if (widgetCfg) {
        var searchWidget = WidgetManager.getInstance().getWidgetByLabel(widgetCfg.label);
        if(searchWidget){
          searchWidget.searchDijit.set("value", "");
Muralidhar,
          return true;
        return false;
      if(!widgetCnfg){
            return true;
          return false;
      return widgetCnfg;
And call this code:
      if (widgetCfg) {
        if(searchWidget){
by Anonymous User
Not applicable
Thank you so much. This code worked perfectly.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
