How to add React JS component to the Widget
1332
06-07-2021 06:11 PM
LaurynasGedminas2
Hey,
Trying to add simple React JS component to the WAB widget getting error:
Widget.js:
/* eslint-disable no-console */
// Load Extrenal Libs
require({
paths: {
react:
'https://cdnjs.cloudflare.com/ajax/libs/react/16.8.6/umd/react.production.min',
'react-dom':
'https://cdnjs.cloudflare.com/ajax/libs/react-dom/16.8.6/umd/react-dom.production.min'
// Widget
define([
'dojo/_base/declare',
'dojo/aspect',
'jimu/BaseWidget',
'jimu/LayerInfos/LayerInfos',
'esri/layers/FeatureLayer',
'react',
'react-dom',
'./_App',
declare,
aspect,
BaseWidget,
LayerInfos,
FeatureLayer,
React,
ReactDOM,
App
return declare([BaseWidget], {
baseClass: 'my-react-widget',
renderWidget() {
console.log(this.folderUrl);
// props
const wab = {
map: this.map,
config: this.config,
const esriJS = {
LayerInfos,
FeatureLayer,
// open/close handlers
const onOpen = func => {
aspect.after(this, 'onOpen', func, true);
const onClose = func => {
aspect.after(this, 'onClose', func, true);
const root = document.getElementById('my-react-widget-root');
ReactDOM.render(React.createElement(App), root);
// WIDGET LIFECYCLE
startup() {
this.renderWidget();
postCreate: function(){
_App.js:
"use strict";
var _react = _interopRequireDefault(require("react"));
function _interopRequireDefault(obj) { return obj && obj.__esModule ? obj : { default: obj }; }
class Car extends _react.default.Component {
render() {
return /*#__PURE__*/_react.default.createElement("h2", null, "**bleep**, World!");
Is even posible?
Thank you
Tags (3)
