I'm trying to customize my pop-ups, so that the square mile field is either rounded or one decimal. I am using the LocalLayerWidget and AccessifizrWidget v1.2. (Maybe the option to format fields can be added to this custom widget?) But for now, it would help if I could just format it.
<b>Area Name: </b>{name}<br>
<b>Approx. Sq miles: </b>{SqMi}
Is there a way to write the {SqM} element to round or show only one decimal place? Do I need to modify one of the files directly?
BTW - I tried to see if I could see how the Online pop-up configuration worked, but although it had a quick format option, I could not see any code changes (I have not tested by downloading from WAB online yet).
If there is no easy way, I know a semi quick option would just add a field to my source and use that. Just looking for a simpler answer.
Thanks for your time.
