how can I disable the connection to portalUrl?
2971
12-12-2015 12:39 PM
NatashaManzuiga
Hi all, I'm trying to work without using any connection outside my local website...
I downloaded the API and I changed the path to point to the API in my website.
How can I disable the connection to portalUrl?
Naty
RobertScheitlin__GISP
Naty,
   It is not possible to my knowledge that are many different files that access portal in the WAB stemapp.
Naty,
NatashaManzuiga
Thanks Robert and once I created and configurated my WebApp application...can I deploy the folder of the App and use it in my "intranet" without a connection to the portalURL?... I'm using LocalLayer widget...so I aspect that I don't need internet connection...
Naty
Naty,
   Nope, still the same scenario there are several pieces of code that are still trying to access Potal.
NatashaManzuiga
Since we can use local layers ...
This should be
an improvement to be made.
I hope ESRI will find the way to add it in the next version of the Web AppBuilder.
Naty
