How can I change the scalebar style in the Print widget?
845
04-12-2018 11:27 AM
ER_Michigan
In the application itself, you can change the style from Line to Ruler. Is there a way to make Ruler the style in the printout itself? I found this post which indicates it's possible to change the units. Just for kicks, I tried adding a line like:
'scalebarStyle: "Ruler"'
but obviously this didn't work. But is there a similar fix?
RobertScheitlin__GISP
Emily,
   There is not layout setting for changing the scalebar style. Your only option is to host a custom print service that uses a different scalebar in the layout.
Emily,
ER_Michigan
Aha gotcha. At least I know for sure now. Thanks!
