District Lookup Widget?
7930
14
10-26-2018 07:21 AM
AlejandraEspinosa
I am working on ArcGIS Online and have added the district lookup widget to the app, but every time an address is searched and the function runs it says "Could not find the point associated with the polygon". How do I get rid of this error so that the widget works without this pop-up window?
St_A
Yes Allison! Thank you! These fields were blank.  Thank you for your prompt response and help. RegardsStella
Sent from Yahoo Mail for iPhone
Stella-MarisAgu1
Hi Allison
Thanks for your help with the school Locator.
Do you know how i can change what shows on the tab where it say "Regular school Elementary boundary" Etc in the attached image. Also is there a way to filter and show only the regular schools and not the french, sort of like a definition query. They are all in the same layer. Thanks for your help.
Regards Stella
AllisonMuise1
The titles are coming from the popup title. This can be configured in the map: Configure pop-ups—ArcGIS Online Help | ArcGIS
You can filter which features you'd like to see by applying a filter to the map layer: Apply filters—ArcGIS Online Help | ArcGIS
The District Lookup widget in your application should honor both of these settings.
Stella-MarisAgu1
Thank you Allison! Everything is working perfect now.
Regards
Stella
JosephRathvon
On a side note; if you want attributes from multiple feature services present in one popup look into arcade expressions. The most recent release will allow you to do this in the popup editor.
