disable the drawbox used in Draw widget and again enable it on check of checkbox in Web App builder
3894
12-21-2015 04:31 AM
IrisGreen
Hi All,
I need to disable the  drawbox used in Draw widget of and again enable it on check of checkbox .
Please suggest any ideas.
Thanks In Advance.
Iris
RobertScheitlin__GISP
Iris,
  In the widget use this code "this.drawBox.deactivate();" then you can use "this,drawBox.activate('POINT');
IrisGreen
Hi Robert,
I tried adding the line of code in 'onOpen' method (as I want the drawbox to remain deactivated after opening too), however the drawBox still remains activated and I can draw graphics on the map.
Iris
Iris,
   OK, I am not sure I understand what you are doing then. The OTB Draw widget does not have any of the draw tools active when it first opens. So maybe you should go into more detail of your workflow and idea.
IrisGreen
Sure , thanks !
