Disable Attribute Popup in Edit Widget
848
08-29-2022 10:10 AM
ZachBodenner
MVP Regular Contributor
I want to use the edit widget to only allow geometry editing. I know that I can disable edit access to individual attributes using custom settings in the edit tool config. But even if I toggle everything off (no visible fields, no editable fields), the popup still opens when using the edit widget. I would love to disable the popup containing the list of attributes when I open the edit widget and select a feature. BUT, I do still need the actual popup window to be configured and available when the edit widget is not active. Is this possible? Can it be done by editing the config files, css, etc? (Web AppBuilder 2.23 in Enterprise 10.8.1, self-hosted application).
Happy mapping,
- Zach
