Customize Multi-Select Widget to Enumerate Selection?
871
01-29-2020 08:47 AM
MikeHines
Hi All,
Completely Love the new Multi-Select capabilities of the filter Widget.
But when using multiple multi-select filters it is sometimes difficult to remember
the selection criteria applied. (without reopening the pull-down)
filter selection pulldown
Currently when a filtered set is formed, the filter Pull-down says e.g. "2 selected".
finished selection
Notice how I changed the hint field to demo the questioned solution...
Do you think it would be possible to modify the "hint" field to hold the values of the selected items?
Potential modification
Inspecting the source elements =
<div class="hint" data-dojo-attach-point="hintNode">John Deere, Terragator</div>
Maybe the close pull-down event could recalculate the particular "hint" field?
Thanks for your consideration!
Mike Hines
MikeHines
P.S.
It appears that the "hint" filed has unlimited capabilities to hold a long list...
hint capabilities
THANKS again.
Mike
