Change ESRI logo Print in Directions Widget WAB
1245
10-10-2017 11:48 AM
ÁlvaroArroyo_Calzada
Hello;
 I would like to know if  is possible to change the ESRI logo image  in the print template of the Directions dijit  included in the WAB Directions Widget, by other image.
 I have tried to get the  img HTML element through its css class and change the src property but the variable is empty because i think that  the directions diit and the print template are different HTMLs.
 You can see a example in:
https://developers.arcgis.com/javascript/3/sandbox/sandbox.html?sample=widget_directions_basic .
The print button is displayed after calculating a route.
You can see the logo in the attached file.
Best regards
saraemani
Did you find the answer? I have the same issue.
AlbertoLópez
Hello;
You can set the printPage property of the Directions class like this:
printPage: "widgets/Directions/newPrintTemplate.html"
GitHub - driskull/print-directions: Print Directions template for the ArcGIS Directions widget. Use ...
Regards.
