Can you change the symbolgy in WebAPP for imported KML files?
729
04-07-2020 05:29 AM
EricCarlson
Hey everyone!
I've built out a Webapp and using the data import widget which allows me to import kml files.  Once in awhile the polygons import but the lines are invisible.  Is there any way to set the default symbology for files that are imported?
Thanks for your help.
Sincerely,
Eric Carlson
RobertScheitlin__GISP
Eric,
   Changing the symbology of the AddData widget has been discussed before.
Change default symbology for Add Data widget in Dev
EricCarlson
Thanks so much! I had searched but somehow I didn't turn up this result. Thank you!
