Can I remove layers from my LayerList in a WAB created map?
31599
52
03-16-2015 01:31 PM
BrianO_keefe
Honored Contributor
I have had to replicate, duplicate, and masticate (it means chew, people) several layers on a web map in order to get them to show up like the clients want them to be shown.
However, now I have a LayerList that is obnoxious with repetitive layers.
Can I remove layers from the LayerList?
And how?
RobertScheitlin__GISP
No wonder you are out of scope then. If you were t use the provided code in a widget then it would work fine.
deleted-user-0W0-oLHxDjCX
Could you just tell me how to add a new method within this javascript widget file?
Thanks in advance.
Ezequias,
   You should start a new thread with your question.
