Border container not displaying content correctly
5313
07-01-2015 03:48 PM
AndrewTerwiel
I have a border container that is not displaying its content panes correctly until I open the Developer Tools console. Can anyone see why that might be happening? I've inserted two screenshots showing before and after display states of the container.
Markup:
<div>
    <div data-dojo-attach-point="infoContainerDiv" id="infoContainerDiv">
    </div>
</div>
Code in widget.js:
this.infoContainer = new BorderContainer({
                style: "height: 100%; width: 100%;"
            this.topContent = new ContentPane({
                region: 'top',
                title: 'the title',
                content: 'I be on the top',
                style: 'height: 100px; border: 1px solid black;'
            this.bottomContent = new ContentPane({
                region: 'bottom',
                title: 'the title',
                content: 'I be on the bottom',
            this.accordionContainer = new AccordionContainer({
                region: 'center',
                style: 'border: 1px solid black;'
            this.accordionContainer.addChild(
                new ContentPane({
                    title: "This is a content pane",
                    content: "Hi!"
                new ContentPane({
                    title: "More content",
                    content: "Hello"
            this.infoContainer.addChild(this.topContent);
            this.infoContainer.addChild(this.bottomContent);
            this.infoContainer.addChild(this.accordionContainer);
            this.infoContainer.placeAt(this.infoContainerDiv);
            this.infoContainer.startup();
Before:
After:
AndrewTerwiel
I've found the cause.
I need to hide the infoContainerDiv when the widget opens, so I have this line of code:
query(this.infoContainerDiv, self).style('display', 'none');
I then want to show the infoContainerDiv after a typeahead suggestion has been selected, so I have this line of code:
query(this.infoContainerDiv, this.domNode).style('display', '');
Removing both of these fixes the display problem.
Now I just need to find a better way of hiding and displaying the infoContainerDiv.
RobertScheitlin__GISP
Andrew,
   Did you add "_WidgetsInTemplateMixin" in your widgets declare and require as instructed in the developer help guide?
Use dojo dijit—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
See this similar thread:
My custom widget doesn't turn a select into a dijit, what did I miss?
AndrewTerwiel
Thanks for your suggestion, Robert. I tried that, but unfortunately it made no difference.
Andrew,
   Please share your whole code for review.
AndrewTerwiel
For easily hiding and showing dom nodes or dijits just use esri/domUtils
esri/domUtils | API Reference | ArcGIS API for JavaScript
