An ArcGIS Service pop up window will not show in web application builder
5711
01-09-2015 07:16 AM
GeorgeKatsambas
I have published a file geodatabase point file as a service. In Flex Application Builder 3.7 and in an ArcGIS online map viewer map I can get the popup window to show the attributes. However, when I create a web application builder map with this same service the pop up window shows a message "No information available". Initially thought as web application builder was in beta there were some bugs. I have upgraded Internet Explorer to IE 10. This is the service.
http://maps.pacebus.com/arcgis/rest/services/APC_Ridership_StrtSvc/APC_WkD_fgb/MapServer
RobertScheitlin__GISP
George,
   The issue with WebMap popups in WAB still exists.
Re: WAB Popup Issue
George,
Re: WAB Popup Issue
GeorgeKatsambas
Thanks Robert, where does one post a bug report about WAB?
George,
   You call esri Tech support.
GeorgeKatsambas
Thanks, I did and they say the pop up should work, so I sent them my data. If they can replicate the problem its a bug. LOL.
GeorgeKatsambas
It seems publishing my data from a shapefile allows the popups to work in AGOL and WAB.
