Adding parameters to WAB print widget
1651
04-21-2017 08:49 AM
JeffPace
I am having trouble adding a custom parameter ( not a customtextelement) to the WAB print widget.
I have added
To my arcpy script, and published it.  However when i load the script as the path in the WAB 2.4 print widget, i get
And the user cannot set the new parameter value.
The ?json response of the script does include the parameter, so i can't figure out why it doesnt display.  It also does not display in the WAB print widget config dialog
{  "name": "Script",  "displayName": "Script",  "description": "print test",  "category": "",  "helpUrl": "http://www.mymanatee.org/arcgis02/rest/directories/arcgisoutput/printing/Script_GPServer/printing_Script/Script.htm",  "executionType": "esriExecutionTypeSynchronous",  "parameters": [   {    "name": "Web_Map_as_JSON",    "dataType": "GPString",    "displayName": "Web_Map_as_JSON",    "description": "print test",    "direction": "esriGPParameterDirectionInput",    "defaultValue": " ",    "parameterType": "esriGPParameterTypeRequired",    "category": ""   },   {    "name": "Format",    "dataType": "GPString",    "displayName": "Format",    "description": "format",    "direction": "esriGPParameterDirectionInput",    "defaultValue": "",    "parameterType": "esriGPParameterTypeOptional",    "category": "",    "choiceList": []   },   {    "name": "Layout_Template",    "dataType": "GPString",    "displayName": "Layout_Template",    "description": "layout",    "direction": "esriGPParameterDirectionInput",    "defaultValue": "staffmap",    "parameterType": "esriGPParameterTypeRequired",    "category": "",    "choiceList": [     "staffmap"    ]   },   {    "name": "Output_File",    "dataType": "GPDataFile",    "displayName": "Output_File",    "description": "print test",    "direction": "esriGPParameterDirectionOutput",    "defaultValue": null,    "parameterType": "esriGPParameterTypeRequired",    "category": ""   },   {    "name": "Include_Attributes",    "dataType": "GPString",    "displayName": "Include_Attributes",    "description": "include_Attributes",    "direction": "esriGPParameterDirectionInput",    "defaultValue": "False",    "parameterType": "esriGPParameterTypeRequired",    "category": "",    "choiceList": [     "True",     "False"    ]   }  ] }
Any Help would be appreciated.
RobertScheitlin__GISP
Jeff,
   Just because you add a new parameter to the print service does not mean that the print widget know anything about that parameter or has any code to use that parameter. You would have to add code and html elements to the print widget to interact and use that new parameter.
JeffPace
oh, rats.  i assumed it would just loop through the list, and present each parameter as a choice based on its settings.  Bad assumption i guess.
Jeff,
   Yep, not that lucky.
