add button to Info Window Pop-up
11113
15
05-02-2016 03:08 PM
DaveOrlando
very similar question to this
Is there a widget or set a serivce on Arc Server to download selected feature from WAB pop-up window...
I have created a Property Report widget (it is just a watered down Print widget using the Export Web Map) but now I'm looking for a simple way to present this to the user. If I could find where the 'Zoom To' comes from I'm sure I can add my own Property Report button in the same fashion.
It would be ideal to place this in the pop-up. In doing so I assume I will have access to the feature's attributes to pass them to my Print code for the customTextElements.
Thanks for any possible help...
Tags (3)
RobertScheitlin__GISP
@fahadrasheed
OK. In 2.16 you would add a popup action. Here is the help doc link for that.
https://developers.arcgis.com/web-appbuilder/guide/create-a-feature-action-in-your-widget.htm
fahadrasheed
@RobertScheitlin__GISP
I tried creating a feature action for popup window but i didn't found all the files for popup widget as mentioned in documentation, I was hoping to add a button by using 'data-dojo-attach-event' and then call the function i want to preform when that button is clicked.
Is it possible or is feature action is the only way forward?
ThankYou,
@fahadrasheed
A feature action is the proper way forward.
fahadrasheed
A feature action seems complicated for a simple task like  adding a button, also popup is not a proper widget which means it does not reside in 'app\widget' folder, I found some files of popup in 'app\jimu.js\dijit' and I didn't find a proper file or folder structure for popup as other widgets have i.e edit.
So how can I follow the instruction which were given in the link you provided when  popup is not a proper widget with complete file structure.
 ThankYou,
fahadrasheed
Thanks a lot, this is exactly what I was looking for.
