add button to Info Window Pop-up
6103
15
05-02-2016 03:08 PM
DaveOrlando
very similar question to this
Is there a widget or set a serivce on Arc Server to download selected feature from WAB pop-up window...
I have created a Property Report widget (it is just a watered down Print widget using the Export Web Map) but now I'm looking for a simple way to present this to the user. If I could find where the 'Zoom To' comes from I'm sure I can add my own Property Report button in the same fashion.
It would be ideal to place this in the pop-up. In doing so I assume I will have access to the feature's attributes to pass them to my Print code for the customTextElements.
Thanks for any possible help...
Tags (3)
RobertScheitlin__GISP
Dave,
  It seems a little easier in 2.0 but either way it involves a little work. In 1.3 you
  1. Copy the PopupHandler.js file from the AttributeTable widgets folder over into your widgets folder.
  2. Rename and modify the this.showRelatedTableBtn to suit your needs (i.e. title)
  3. Rename and change the _onRealtionshipClick function to do your work
  4. Add the popupHandler code and require to your custom widget:
// create PopupHandler
        this.popupHandler = new PopupHandler({
          map: this.map,
          myWidget: this,
          nls: this.nls
Dave,
  Are you talking WAB 1.3 or WAB 2.0 as the methods for addign buttons to the popup have completely changed in 2.0?
DaveOrlando
Lovely, I will need to learn both or else I'll be stuck in 1.3 until I do.
Let's start with 1.3 for now.
Is the 2.0 technique significantly easier, or just different?
Dave,
          map: this.map,
          myWidget: this,
          nls: this.nls
DaveOrlando
This is great, I'm 95% there, but the button will only appear if the widget has been previously opened (understandable).
I've read some of your other answers regarding loading a widget at start-up but keeping it invisible. I also started with an in-Panel widget (Print) but I don't need the UI anymore. where can I initiate the widget to allow the popupHandler to initialize?
I've tried this but to no success.
"widgetOnScreen": {
  "widgets": [{
            "uri": "widgets/PrintDemo/Widget",
            "position": {
                "relativeTo": "map"
            "version": "1.4",
            "id": "widget_PrintDemo",
            "name": "PrintDemo",
            "label": "Print Demo",
"config": "configs/PrintDemo/config_PrintDemo.json",
"visible": true
any other suggestions?....
Dave,
  If you do not need a UI anymore then delete you Widget.html and edit your manifest.json to be
inPanel: false
hasUIFile: false
hasStyle: false
DaveOrlando
Thanks I got it working!
it should be mentioned that the above attributes need to go into a 'properties' element
"properties":{
"inPanel": false,
"hasUIFile": false,
"hasStyle": false,
"openAtStart": true
Thanks again, your help and contributions to the forum are invaluable and very appreciated!
Dave
fahadrasheed
Hi Robert,
Can you explain me a bit how can one achieve this in version 2.16 of WAB Developer Edition. It'll be of great help. I also want to add a custom button or hyperlink text in Popup window of my app. Take a look at attachment for better understanding.
Thank You,
@fahadrasheed ,
The steps are still the same as outlined in this thread above.
fahadrasheed
@RobertScheitlin__GISP  ,
I tried following the procedure mentioned above but couldn't found the  'PopupHandler.js' file in Attribute table widget. Also you mentioned that this procedure is for version 1.3 but i'm using version 2.16. I have added a screen shot of attribute table widget file.
Thankyou,
