There are 5 placeholders for adding widgets in billboard theme.
How to add one more placeholder to add a widget?
Regards,
Shaikh Rizuan
Shaikh,
Open the \client\stemapp\themes\BillboardTheme\layouts\default\config.js and add a new place holder as shown below in lines 84-89 or if it an existing app that you want to add the placeholder to then you open the \server\[app #]\themes\BillboardTheme\layouts\default\config.js:
{ "widgetOnScreen": { "widgets": [{ "uri": "widgets/Search/Widget", "position": { "left": 60, "top": 10 }, "version": "2.1" }, { "uri": "widgets/ZoomSlider/Widget", "position": { "top": 10, "left":15 }, "version": "2.1" }, { "uri": "widgets/HomeButton/Widget", "position": { "left": 15, "top": 80 }, "version": "2.1" }, { "uri": "widgets/MyLocation/Widget", "position": { "left": 15, "top": 120 }, "version": "2.1" }, { "uri": "widgets/Scalebar/Widget", "position": { "left": 15, "bottom": 25 }, "version": "2.1" }, { "uri": "widgets/Coordinate/Widget", "position": { "left": 15, "bottom": 5 }, "version": "2.1" }, { "uri": "widgets/OverviewMap/Widget", "position": { "right": 0, "bottom": 0 }, "version": "2.1" }, { "uri": "widgets/Splash/Widget", "visible": false, "position": { "relativeTo": "browser" }, "version": "2.1" }, { "position": { "left": 60, "top": 53 } }, { "position": { "left": 105, "top": 53 } }, { "position": { "left": 150, "top": 53 } }, { "position": { "left": 195, "top": 53 } }, { "position": { "left": 240, "top": 53 } }, { "position": { "left": 285, "top": 53 } }] },
Hi Robert,
I did those changes earlier also but no luck.. I am not able to see the placeholder in Widget section.
Shaking,
Are you changing the proper file? The one in the apps folder?
Robert,
I did it in correct file for an existing app.
This is the location path: ....\arcgis-web-appbuilder-2.0\WebAppBuilderForArcGIS\server\apps\5\themes\BillboardTheme\layouts\default\config.json
I got the new placeholder while after creating the new WebApp.
Sorry the code I provided is only for new apps. If you want to add a new placeholder widget for an existing app then you have to manually add it to the main config.json in the widgetOnScreen widgets array.
Signed in members can post, follow updates, and more. New here? Register a free account.
